631G
The rear drive shaft let go and has knocked a hole in the transmission housing and unfortunately we not only got a new drain hole in the transmission, but also a nice long crack running to the matting surface between the trans and the transfer case. So she has got to come out. Does anyone have a procedure I can refer to with my mechanic to perform this removal? I checked the manual I bought for the machine, but its not got much for major component removals like this.
Also for anyone interested, below are some photos of where we cut out the bad spot in the housing and found that this transmission had apparently already had this happen in the past and been brazed back together.
SN: 17Z01334
SN: 17Z01334
