763 Bobtach Wear
Discussion in 'Skid Steers' started by KyDirt, Jan 3, 2018.
  1. KyDirt
    KyDirt Member
    Jan 16, 2015
    22
    Construction Superintendent
    London Kentucky
    The bobtach on my bobcat has excessive play from right to left between the loader arms at the pivot pins. I have replaced a set of pins and bushings before (not this machine) and though these probably need replaced , that won't help my side to side movement issue from what I can remember about my last rebuild. Do they make shims to go between the loader arms and bobtach?
  2. xgiovannix12
    xgiovannix12 Senior Member
    Feb 22, 2012
    474
    Operator/Mechanic/Truck driver
    New York
  3. xgiovannix12
    Feb 22, 2012
    474
    New York
  4. TriHonu
    TriHonu Well-Known Member
    Apr 18, 2007
    135
    Minnesota, USA
    My 763 was the same way when I bought it. I measured the amount of play and removed the QuickTach and measured the diameter of the pins.
    I bought shim washers at the local FleetFarm. You can buy the washers in different thicknesses. I bought a couple different thicknesses and stacked them until the fit was what I wanted.
    Mine also had felt grease seals (felt washers) to help keep dirt out of the pin bores in the QuickTach
  5. KyDirt
    KyDirt Member
    Jan 16, 2015
    22
    London Kentucky
    Sounds like the simple cost effective solution.
