Ha, try WalMart, Homedepot hobbyist welder's section you'll be able to purchase a better wire for your project.
Short video, kid welder want-a-be after 5 minutes of instructions by my neighbor, a 35yr plus professional welder just off a off-shore project. Vertical Up and Overhead; the youngster will qualify for AWS All-positions.
Steve sorry,
After 65yrs of welding I am worn out from giving how-to advise. Lincoln Outershield 71M is a very forgiving, easy to use wire!!!!!!!!! Your Miller 210 will run 71M using Reverse Polarity versus Straight Polarity; bit of extra duty cycle time. 71M feeds good (harder and stiffer), doesn't stick @ mig-tip from overheating like ESAB or Hobart wires.
Example photos of using 0.045" 71M completely 'out of normal parameters' and ignoring welding procedures bell-whistles and lollipops . Cast hardened steel parts coated with tungsten carbide hard facing.
View attachment 190675 View attachment 190676 View attachment 190677
Must work emergency fix it. Supplier ran out of replacement teeth the come from Spain via air-freight.
PS: don't use keyway stock to fill gaps. Bang a stick of 7018 against the steel arm to knock the flux off, way cheaper.
