Onfoot
Hanna the Grader (my '68 12F grader) is running well and earning her keep with all the snow we've been needing to clear this month. But there is an issue with the circle control in the power control system. Circle turns fine clockwise. But counter clockwise intermittently results in an unhealthy clattering noise. And on Friday, there was the noise and then sheared the shear pin. After 3 more shear pins, I turned the circle clockwise without issue and did a bit of plowing before needing to turn counter clockwise again. But this time it moved counter clockwise with no issue.
I'm very much a newbie in all this and the maintenance manual does not have much to say beyond a general description of the Power Control box. If I had to guess, it would strike me as a gear with a bad tooth that gets caught in the bad spot sometimes...)
Any wisdom out there about something like this? Thanks!
