What kind of equipment is the "670" and what brand/model are the directional valve and the pump?
Do you get pump pressure activating any other functions?
I assume you have a CPU or LS hydraulic system with a variable displacement pump. If so there is a hydraulic line, probably 1/4" in size, that transfers a pressure signal from the directional back to the pressure compensator on the pump. How this pressure signal is generated depends on who made the directional valve. So just now with limited information, the only hint I can give you is that there can be a small orifice, 0,7-1.0 mm diameter that is clogged up with debris.
This is Parker's way to design a CPU, Constant Pressure Unloaded system.
The orifice is located between the main pressure line from the pump and the signal line that goes back to the pressure compensator on the pump
