624H coolant in oil
mattyt1984
New York
I bought a deere 6024 h and I got it running had a little miss so I shut it down because I did not see coolant in it. I put water into the radiator and noticed the engine oil rose up on the dip stick. With in minutes the water I put in the cooling system ended up in the engine oil. IS there anything common on this that would cause such a massive leak from coolant into engine oil??
mg2361
Pennsylvania
Equipment Mechanic
Is the misfire new? The oil/coolant mix start a the same time as the miss? Did it smoke when it missed? What color was the smoke and did it have a fuel smell or a sweet smell? That may give a clue as to which cylinder may be a problem. There is only several places for the transfer to happen.
1. Engine oil cooler (which I would check first)
2. Head gasket/cracked head
3. Piston Liner (either electrolysis or liner o-rings)
4. And very, very rare but I seen it once is the water pump being shot and wearing a hole in the timing gear cover. That was a water pump with a metal impeller, though most of those engines did have plastic impellers).
mattyt1984
New York
Im not sure about miisfire as I bought it like this at an auction. It has the coolant drained with clean engine oil. No smoke out exhaust but a little bit out of the breather when it started. Whatever it is leaks like a gallon of coolant into oil in a few minutes.
mattyt1984
New York
I removed cylinder head today and definitely a major issue cylinders 2 3 and 4 are all at top dead center. Number two cylinder must have broken connecting rod. Will the oil pan come off this without removing the engine looks like at minimum I would have to remove the fuel tank?
heymccall
Western Pennsylvania
On my 544G,H, &J machines, it's easiest to just take out the engine.
Disconnect shaft from motor to converter, rest is straight forward (mounts, hoses, wiring, ac comp, fan drive pump, etc.)
