623B
Discussion in 'Scrapers' started by typ4, Jun 30, 2018.
  1. typ4
    typ4 Well-Known Member
    May 23, 2010
    205
    Equipment mechanic for a small company.
    oregon
    Gentlemen,
    So, im not experienced on Cat equipment,
    Can the stator be repaired in the torque convertor from the back without pulling the trans diff package out?
    Thanks in advance
    Russ
  2. Nige
    Nige Senior Member
    10,778
    Don't think so, but others may have differing opinions. Here is the D&A
  3. typ4
    May 23, 2010
    205
    oregon
    We have it apart and if the book is correct, since it is clear as mud, the cam ring was in backwards. New one is clearly marked impeller side and is now installed correctly..
    Cat builds things differently.
  4. typ4
    May 23, 2010
    205
    oregon
  5. d9gdon
    d9gdon Senior Member
    Feb 12, 2010
    1,349
    central texas
    Did you recently rebuild it and put it in wrong or was it that way for a while?
  6. typ4
    May 23, 2010
    205
    oregon
    We just bought the machine. It was in right. I matched wear pattern on thrust plate. Testing tomorrow.
    Problem was it wouldn't climb the pile , acted like it just powered out. 1st & 2nd.
    Almost pulled it in third, which if I understand correctly goes around the convertor.
    Only thing common in those two gears is convertor and clutch 1
  7. Nige
    Nige Senior Member
    10,778
    Is there a chance that the freewheel mechanism for the stator is acting up and not locking the stator in position when it’s in converter drive..? That would give you symptoms just like converter stall.
  8. d9gdon
    Feb 12, 2010
    1,349
    central texas
    The 623B had a unique variable capacity torque converter. Seems like there was an air valve associated with first and second gears to send more power to the elevator, so it would make sense for it to vary torque converter operation as well. A service manual transmission operations section would clear up my foggy memory.
    Nige, maybe you can explain how that works or if it's part of his problem?
  9. Nige
    Nige Senior Member
    10,778
    Good point Don. I’ll see if I can find the SysOp for it and post back. It may be a while, I’m out & about @ the minute.
  10. Nige
    Nige Senior Member
    10,778
    Here's the SysOp. I assumed it was a 46P-prefix machine. It covers the operation of the variable-capacity torque converter in some detail.
  11. d9gdon
    Feb 12, 2010
    1,349
    central texas
    Ah hah, I thought I remembered an air valve in the mix somewhere. It should make an air sound when shifted into 1st or 2nd gear slots toward your knee.
  12. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    809
    heavy equipment technician
    victoria,Australia
    Hi, I am trying to understand what you mean by ( acted like it just powered out. 1st & 2nd )
    do you mean the machine slowed down and engine speed stayed the same or that engine lugged down to near stall ?
    do this simple check. operate the machine under load with the elevator engaged
    if the elevators slow down it is possible that the safety clutch in the flywheel housing is slipping
    Note many a transmission/convertor rebuild has occurred for no reason from incorrectly diagnosing this clutch
    Mark
  13. StanRUS
    StanRUS Senior Member
    Mar 7, 2016
    736
    Cal
    Early 623s 46P to 1023 do not have a flywheel safety clutch, unless the machine was upgraded.
  14. d9gdon
    Feb 12, 2010
    1,349
    central texas
    Did you get it fixed?
  15. Mark250
    Aug 30, 2015
    809
    victoria,Australia
    Hi Stan unfortunately the op has declined to offer a serial number. I picked the later serial number break as I know a lot of machines were converted over time (have done quite a few myself) if any one is interested I have a copy of the conversion procedure and the media number
    Mark
