Canuck Digger
- Joined
- Dec 24, 2012
- Messages
- 264
- Location
- Mission, BC, Canada
- Occupation
- Business Owner, Equipment Operator, Fishing Guide
I'm starting to look around for a 6 ton (ish) mini/mid size excavator. There seems to be a lot of 5 and 5.5 ton machine from the different manufacturers, however, once you get to the 6 to 6.5 ton mark, the choices seem to be pretty limited. I currently run a JD50C, which has been a pretty good machine. It's a bit slow, but very reliable. The main goals I hope to accomplish by getting into a 6 ton machine (with a long stick) as oppose to to 5 or 5.5 ton are as follows longer reach, better dig depth, and mainly more lift weight. I'd like to keep it to a reduced tail or 0 tail swing as we quite often work in pretty tight areas. The machine will be doing landscape construction type jobs, building access roads, small demos, pool digs, small foot print brush clearing, stacking rock boulder walls etc. I'm set up to tow a 6 to 6.5 ton machine on my own. I also have a 3.5 ton machine, and other than the lift capability there is no difference between the 3.5 ton and the 50C. My choices seem to be a JD 60 D or G or a Wacker Neuson 6003. I'd welcome constructive feedback on those two machines as well as suggestions for any other ones that would fit the bill. Must haves are: reach over 20' dig depth over 13ft. and dump height over 13ft. Look forward to your comments
