6.7 Cummins Crank No Start
Discussion in 'Wheel Loaders' started by dieseldog5.9, Jan 16, 2020 at 4:00 PM.
  1. dieseldog5.9
    dieseldog5.9 Well-Known Member
    Aug 11, 2014
    129
    New Hampshire
    6.7 Cummins in a LouGong G856 Loader. Operator changed the fuel filters he thought gelled up. After changing the filters it ran a few minutes died and hasn"t run since.
    Spent quite a while priming the supply side of the fuel system, and am confident that is good, however the high pressure side i am not confident in, are there any special instructions for priming the high pressure side, big warning label on high pressure manifold about not opening injection lines, however old time machines need the lines bled.
    Tried hooking older Nextiq scanner to the loader and it picked up no ECM available, not sure if this is due to being a LouGong, the fact it is a truck scanner, older programming, or the ecm is dead and that is what killed it in the first place.
  2. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    2,807
    Were the filters gelled up when they were taken off? If so there could be gelled fuel in the rest of the fuel system. Do you have a way to warm the machine up?
  3. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    2,534
    Mechanic
    Will county Illinois
    Back to basics. Why were the filters replaced? Had the machine stalled already, was it low on power? Have you got a schematic for the machine? Have you checked your fuses? Does it have a Cummins ECM or is it the manufacturers. Do you have ECM fuses near the batteries or by the starter? What level of emissions do you have? III, IV Interim or IV final. I dont think they came over till we were into tier IVi .
  4. AllDodge
    AllDodge Senior Member
    Apr 2, 2011
    1,446
    Kentucky
    A 6.7 is easy to bleed the air out, or at least all of them I've worked on.
    Turn key ON, just bump starter (do not crank) and listen for the fuel pump to stop.
    Turn key OFF, Turn key ON, bump starter and listen for pump to stop.
    Repeat this 2 more times, Turn key OFF, it should be good to do one more time and start
  5. partsandservice
    partsandservice Senior Member
    Feb 14, 2011
    679
    Georgia
    It would seem there would at least be warning lights light in the cab yellow and red if not some kind Murphy display or the like. If there are warning lights , when key on they should both light up then go off, if they don't come on at all the ecu is not powering or you have a possible no data connection to a dash module if equipped.
  6. dieseldog5.9
    Aug 11, 2014
    129
    New Hampshire
    Ok so got this figured out, so I was building an engine in the shop by the woodstove when owner came in said loader quite, he panicked and called dealer, scheduled a visit from the big fancy service truck, because the bigger and newer the service truck the faster better the repair is, oh fancy decals help too. They will be there next week. Ok he has it handled I will stay in my lane. This is Wedmesday.
    Friday another major manufacturer was onsite for a leased dozer, asked to have a look. He spent the day, after replacing the fuel lines from the tank decided it was the high pressure pump.
    Tuesday Dealer came after paying 120 mile road time each way, arrived 11am, left at 4 mostly on phone in truck. He had to call dealer for result, they Said load it on trailer take it to our shop. Owner says it's dead can't load it, not our problem.
    I was called for a crane out of fuel on same site, asked if he wanted me to looke at loader. Spent some time priming system found fuel line that was replaced kinked at the tank, got fuel system primed each section to high pressure pump separately, removing filters and lines up to pump. Ran scanner got no ecm picked up. -5 degrees and 5pm so dark. Checked fuses and fuse links at battery.
    Retreated to my office posted on HEF, found a trouble tree for crank no start, sat down worked through tree made notes to check, returned to machine found Ecm power slightly unplugged. Fired it up. Loader downtime from me 1 day. Downtime from dealers over a week, who knows how long they would drag it out but hp pump and low bed ride would cost $5000, jobsite working 7days a week 12 hr days.
    I think owner was gelled, when changing filters didn't prime machine correctly, other issues I believed caused by faulty workmanship. I showed up in a 10 year old pickup with no letters on the door.
    partsandservice, Nige and funwithfuel like this.
  7. funwithfuel
    Mar 7, 2017
    2,534
    Mechanic
    Bwahahaha K.I.S.S. :)
    Good deal good catch.
  8. partsandservice
    Feb 14, 2011
    679
    Georgia
    I find that is often more than one issue. Also it seems like that when techs have all the latest and greatest software it is relied on too heavily. It is still just an engine regardless of the teir level. Good for you, you will go far.
  9. funwithfuel
    Mar 7, 2017
    2,534
    Mechanic
    Emissions are to be considered when dealing with fuel systems. Some larger engines have fuel dosing nozzles which parasite off the main fuel system. So yeah tier level and displacement matter.
  10. partsandservice
    Feb 14, 2011
    679
    Georgia
    I agree that Emissions matter, the point I was trying to make is that under all that stuff is the same old engine that still needs the three basics to run. Regardless if how those basics are controlled or administered. Like you said K.I.S.S.
    funwithfuel likes this.
  11. dieseldog5.9
    Aug 11, 2014
    129
    New Hampshire
    Well, I am not a pup, the sorel boots I wore all day today are older than the first guy that showed up on the jobsite, actually he has probably never heard of them before.
    I think in these days with all the computerized this and that guys forget about good old fashioned police work, rely instantly on scan tool, I went to diagnostic tree and read the f***ing thing, which is the step so frequently missed today.
    Oh and luck helps.
