A STRAIGHT flat file, or round straight file, with the ends covered just enough that it will not file a flat surface, might file the hump out without extending past the damaged area. A chrome cylinder rod can be carefully smoothed with a flat file, as the file will ride on the chrome and cut only the hump, the inside cylinder will be softer than chrome, so even a few layers of paint might be enough to cushion the ends of the file to keep from digging in.
Valve grinding paste could also be used once it's closer to the final dimension, but probably not needed, sanding would be close enough.[/QUOTE
From what I can tell, the bump goes to within about 1/4" of the bottom of the barrel which could make it difficult to get to all of it with a file. It's longer than I initially thought too and there's a rough area in front of it that needs attention. All in all maybe an inch and a half or more long. Kinda making me lean towards shortening the stroke.
