bowen
I wonder if the inner valve has been out before & maybe put in the wrong way???
All I know is that it works great otherwise. The only thing I noted was that the little lip seal seemed to fit loose in the groove.
(Horizontally, not loose on the shaft)
Then I had to REALLY tighten the solenoid to stop it from leaking. Still when I do the warm up - it leaks a tad.
With the solenoid off the shuttle, the transmission should not engage if selected - what happens if you start it up & try to drive?
My cooler is off so I cannot crank it at the moment. Also I have no fluid. I wish I has already tried this but I thought oil would spray out all over the barn. Maybe I will install the cooler and add the oil, then try this before installing the solenoid.
The 1st time I changed the fluid in late 2011 the oil looked nasty as if it really needed changing but I did not see any significant metal or items on the screen. Maybe some small specks. Even this 2nd oil change was still cloudy after only 25 hours of use. And I DID get the oil out of the TC again...
So far this time I have only removed the plug, not the bottom pan.
I see that Coleman gets $410.80 for a # N13639 valve assy! I think mine did have two of the o-rings...
