bowen
I had found the Case tool # CAS1690A from Coleman for like $45, but online it says "discontinued".There is a engine turning tool you can purchase from Case or Snap On # YA9565A - they are slow, but makes it real easy
Snapon online says $65 maybe. I would like to have one. Also good when getting the hyd pump coupling off.
I am going to find that plug, get the oil changed and then work on the other later to be sure the leak is really the control valve.
I have other issues. The neutral switch must be jumped out because it will start in gear.
Also the clutch solenoid button on the bucket lever does nothing. I need to get all this cleaned so I can find the parts.
I am surprised to read that the clutch solenoid just "screws off".
I suppose I would need the o-rings item 50. I already ordered 43 & 49.
I do not know yet if I need a new solenoid or have a wiring problem. My fuel tank shutoff valve was leaking pretty bad and fuel was all over the shuttle area.
Right now I have all the air box assy off, all cleaned and painted, and plan to remove the fuel tank to clean and paint it. I have new valves ordered for the tank also.
Thanks for the help, and I sure need it.
