580K stuck in 1st gear
Discussion in 'Tractor/Loader/Backhoes' started by whatwas, Jun 14, 2019.
  1. whatwas
    whatwas Well-Known Member
    Apr 12, 2011
    60
    ontario canada
    My 580K (4WD phase 3 shifter on side console) has 7500 hrs and has always needed a firm hand to engage 1st and 2nd gear but has always worked. It now is in first and the shifter moves freely (too freely) between 1st and 2nd but stays in first. If you shift to 3rd or 4th than the trans locks up, seems to be engaged in two gears at once. I'm thinking the trans shifter fork/internal linkage has broke or slipped out of position. I need help to inspect or confirm whats not right.
  2. Coy Lancaster
    Coy Lancaster Senior Member
    Dec 19, 2014
    1,122
    service tech
    Arkansas
    Sounds like you have a broken shifter fork. You’ll have to remove tranny and pull front cover to check it out.
  3. whatwas
    Apr 12, 2011
    60
    ontario canada
    Thanks for the reply Coy.
    Is there somewhere online where I can get access a service manual or buy one. Looking at the manual that I got with the tractor, its for a unit with the shifter on the floor.
  4. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,683
    On A Riverbank in IL. USA
  5. alrman
    alrman Senior Member
    Jun 20, 2009
    2,675
    QLD Australia
    @whatwas - I would be taking a close look at the selector control operation, under the machine, while having someone move the gearshift - before you just pull it apart.
    MinnPar list a free service manual for the SK - HERE
    kith likes this.
  6. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    4,501
    Andrews SC
    I would pull the rods off the shift linkage on the side of the transaxle and see what it felt like with a pair of channellocks, too. worn sk shifters will hang up
  7. whatwas
    Apr 12, 2011
    60
    ontario canada
    ok, so it took me awhile but I dropped the transaxle and turned it up on its back to remove the the end plate. I found the 1st-2nd gear shifter shaft had the end plate weld broke . The price for a new one was crazy ($1264 Can.) so I cleaned it up and re-welded it, fingers crossed. I got everything back together and the shifting feels good, better than before, but need to get the case brake TCH oil and bleed the brakes.
    so any tips on finishing this project off would be much appreciated. Thanks
  8. Coy Lancaster
    Dec 19, 2014
    1,122
    service tech
    Arkansas
    Good luck
