580K-New battery-Starter smoking
Ed1
Chattanooga, TN
Hey guys,
The last two times I went to start my 580K it was tough. Turning the ignition would just slowly turn the motor over. I assumed the battery was shot, put a charger on it overnight and it only got to 60%. I bought a new battery and installed it. Yes, my polarity is correct. Yes my cables are good. Same thing happens when I go to start it, only now the lug below the starter glows red, the starter gets super hot and starts smoking. What's the deal? Please don't say the starter is shot!!!
Ed1
Chattanooga, TN
New problem. It the time it took me to post that, I went back to it and now the starter doesn't engage at all. I hear the click of I'm the guessing the solenoid when I turn the ignition, but the starter doesn't budge. Help!!
funwithfuel
Will county Illinois
Mechanic
What lug is "glowing?" You likely have a ground fault.
How do you know your cables are good? Did you perform voltage drop test? Does your starter have a dedicated ground cable/strap or is it grounded through the case? Either way, clean your grounds . Start at battery, move to frame, engine block, starter etc. When you're done, spray paint to prevent future corrosion. The fact that you stated a lug was glowing indicates you had serious amperage crawling through poor connections which may have shortened the life of your starter. 325e2f02ed507b5d4bed57ef4c416884.jpg
Ed1
Chattanooga, TN
This one.
I tapped on the relays and starter and now it's turning over, but still really hot
Slow down and don't wreck more. How long are you cranking for this to happen? The obvious answer is the starter is burned up, and if it wasn't the cause of the problem, it's burned up by now.
Something big is wrong for this to happen. The glowing means to me that the battery is probably fine, but it wouldn't hurt to test the cranking voltage at the battery, and resting voltage. Then the cranking voltage at the starter. That will tell you where to look next.
First thing I'd check is how hard the engine is to turn over by hand. It should turn a small fraction of a turn back and forth easily. It will get tight as one cylinder builds compression, but wait a few seconds and it will turn another small fraction the same direction. If you can't turn it by grabbing the fan and belt, something is wrong.
funwithfuel
Mechanic
Ok, so you have a high torque reduction starter. You have 2 choices. Completely remove starter, Emery cloth the face of the starter and block. Wire brush the screws and place tooth washers under the bolt heads. This bites into both the bolt and starter to promote ground. Remove and polish hot feed to solenoid and alternator feed cable. Last thing is a personal preference thing. I like to add a 10 or 12 ga wire to the mounting screw of the starter from the chassis. This is a supplemental ground. You don't want it too big, you could have a ground fault electrical fire that way.
Those starters are pretty reliable and don't require the amperage of the old direct drives.
Let us know how it shakes out.
Just saw Delmers reply. A little lag there.
Ed1
Chattanooga, TN
Thanks guys, I didn't bring a voltmeter to the shop with me, I'll have to start buzzing it out next weekend. Thanks for the tips!
Ed1
Chattanooga, TN
Hey guys, just wanted to let you know, the starter got put on the back burner do to fuel pump stuff. I pulled the starter and cleaned everything from the battery forward. The ring terminals were shot on the hot side of the circuit. So all new terminals. The grounds had so much grease and gunk caked on them I'm shocked the starter knew the key was on at all lol. The wires tested ok so I left them for the moment. They will all get replaced eventually. Cleaning up the grounds made a huge difference in the starters performance which was to be expected. Got the fuel issues resolved so now I'm not having to sit on the starter so long. Everything is great now, no more glowing!!
fast_st
Mass
IT systems admin
Yeah, sounds like its worth while cleaning all the connections hot and ground and maybe replacing that cable end on the glowing terminal, it might be okay though but possibly damaged. Die grinder with a wire wheel works great, or those scotch disks, Starter might have some issue, a lot of amps are going to heat, have a starter shop give it a bench test.
Ed1
Chattanooga, TN
I did replace the ends. I was ready to take it for a rebuild, but so far everything is working as it should. I think it was two issues: 1. I was dealing with fuel issues which made me sit on the starter longer than I knew was good, but did it anyway cause I'm human and a man and just give me a bigger hammer lol. 2. Every connection between the battery and starter was crap.
fast_st
Mass
IT systems admin
Good deal then! Had a friend bring an RV slow starting, seems not charging, charged batteries and found 14 bad connections, couple hours of cleaning every terminal and connection to the starter and alternator, seems it was a bad alternator to begin with but now all the connections are pristine!
  • Like
Reactions: Ed1
fast_st
Mass
IT systems admin
Every junction was corroded and all but one ground connection was dodgy. Prev owner replaced a few sets of batts. The alt must have been broken for years, the two hour drive from home to camp and back wasnt enough to use up the power before it was plugged into shore power again
funwithfuel
Mechanic
I think what vetech was getting to, the starter was searching for ground, its gonna find it where it can. Prolonged 'crank' with poor ground/cable/lug has resulted in all kinds of crazy stuff. Welded u-joints come to mind. Had a power steering hose light up and start a truck on fire. I've also seen welded pilot bearings. Electricity is wild sh!t.
KenO
Snowflake, AZ
Jack of all trades - Master of none
Just joined the forum and was browsing through some posts:
I've had an intermittent starting issue for a while, figured it was a ground somewhere. I'd keep checking all the grounds associated with the starter and could find anything loose. Thanks, I bet this fixes my problem.
Ed1
Chattanooga, TN
Welcome KenO!
Clean everything between the battery and starter, replace terminal ends. If that doesn't help the starter may need to be rebuilt.
