Steve 580ck
Hi guys, I have a 70 580ck. First post on here I have rebuilt the engine and shuttle clutch packs and now I'm trying my luck at the dipper rebuild, this is the first of many more but it started gushing the other day instead of the normal drip its had. Gland was a real pita until I pushed the rod out and realised the rod was bent. Ordered a seal kit and the replacement rod g105087 which looks to be the replacement for d37728. The new rod is slightly bigger than the old rod, sorry but I dont have an accurate measurement for you but I know it's only a hair bigger. I bored out the gland just enough that it comfortably fits over the new rod and I need to bore the piston out a little as well. Just wondering if anyone has any advice or know if the gland and piston off a 580c will fit my cylinder. I know the first thing I am going to hear is if I cant get you an accurate measurement I shouldn't be boring it out, this machine is for personal use and worse case I'm back where I started! I would like to give a shout out to Phil, I've been up and down the forum before signing up and your posts along with many others on here helped me through the previous rebuilds! Steve
