580c 207 intake manifold made of?
kshansen
Central New York, USA
is it aluminum or steel? Easy to weld?
Well first test would be to touch with magnet! If it sticks then steel or cast iron.
And "easy to weld" would depend on one's equipment and skill set.
Really not trying to be a jerk here but sometimes it might come out that way!
mitch504
Andrews SC
:oops:Wow! I am getting to be a REAL internet user! I saw manifold and looked right over "intake"!:oops::(
I'm sorry, it should be aluminum and probably needs to be tigged.:oops:
Billrog
Armstrong, British Columbia
band mill , backhoe and dump truck
:( it was my exhaust that had been brazed after it had been broke from driving under a low roof by previous owner.
It would be worth having some one aluminum weld it up for you depending on the nature of the problem. The used ones I looked up are
around $200
If you don't want to take it off, use silicone gasket maker. It's only engine vacuum, no throttle plate so the air filter is the only restriction.
