580 super m
DS1973
west virginia
I have a 580 super m squirting fuel from the breather hole above the fuel injections lines any idea what could cause this thanks
Tinkerer
Welcome to HEF, DS1973 !
Breather hole ??? Can you explain that a little better ? I think you need to have three posts on HEF before you can post a picture. Photos certainly make helping us a lot easier.
DS1973
west virginia
20190317_120315-1.jpg I assume it is an overflow or a breather hole on the fuel injection right under what looks like a solenoid valve or a shut off valve on top of the fuel injection pump I cannot find a description of in my parts manual thank you for your reply20190317_120315.jpg
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
THAT is indeed a "vent".. A rubber diaphragm is captured right above it in the boost chamber & gets pushed down.. & the motion needs to be vented..
What is leaking is a small, & I mean SMALL oring, that seals on a rod..
Sorry but its not a diy project & unless u find a VERY EXPERIENCED pump guy to remove JUST the top cover, the pump HAS TO come off.
Pump removal isn't that hard if u have the engine turning tool..
CLEAN the pump area before starting the project..{Brake-Kleen}
I can take care of the leak once u get it off..
The drive shaft might NOT BE keyed.. so the timing procedure is critical on that engine.. & the pump & engine need to be timed before pump removal..
Good luck.
DS1973
west virginia
This has been the best form I have ever joined, thank you
Im sure I can remove the top cover with no damage to the pump, I have experience drilling covers with bolts, is there a professional repair that needs done, or just replacing the oring, I'm sorry for all the questions but where I live if I want something fixed I gotta do it my self,
thepumpguysc
UNLESS your getting a professional inj. pump guy to do it, don't try it..
Take the whole pump off..
The repair needs to done professionally.. it is NOT a DIY job..
thepumpguysc
IF u have a book, that's great.. if not, post back & we can walk u thru it..
Do u have the engine turning tool.?? it makes the whole job WAY MORE fun..
thepumpguysc
The way I like to do it is>> use a small screwdriver to pull the retaining clip off the timing pin..
Pull the pin out.. take off the oring & lube the pin.. THEN rotate the engine..
The oring will keep the pin from falling easily into the hole in the cam gear..
& sometimes I wont use the pin at all.. I'll stick my little finger in the timing hole & FEEL for the hole in the cam gear..while I rotate the engine..
alrman
QLD Australia
Many of those Iveco engines don't actually supply the timing pin..... only the hole in which to insert it.
Nice marketing ploy ;)
Coy Lancaster
Arkansas
service tech
Of course these Iveco pumps are mounted on the rear of the engine and a pain to get off at times. Case had an issue with the early units being not timed correctly out of the factory and dealers had to retime engines using a fixture supplied by Case. But as pumpguy said remove the timing pin cover and find the hole in cam gear before removing the pump.
DS1973
west virginia
OK it rained all weekend but I did read up and have more questions where can I get the gear puller mentioned in the manual or can I use one similar all I have are bearing and hub pullers
