Well I wanted to give an update on my fuel issue now that everything (knock on wood) has been fixed.
NH575E was correct about one thing, boy were those banjo fittings clogged up with a bunch of crud! Honestly I think this was the culprit, but we decided to replace all of the gaskets, washers, and o-rings for the whole bowl assembly. I also put an inline filter in to try and prevent this from happening again. Just for the heck of it because I figured they were original, we replaced the supply and return hoses.
Next up, we replaced some of the “olives” on the hard lines going to the filter housing and then going to the injector pump. We did have an issue with these. Someone suggested purchasing these from eBay:
https://www.ebay.com/itm/Set-of-10-...333260?hash=item4b6db82a8c:g:Y~QAAOSwTtZfc3od
While they did end up working, the ones I got from this link were not thick enough. When we put one on each end of the tube, once connected to the fitting, the tube would be loose and would not seal. We tried using a piece of 5/16 hose, but it was slightly too big and the nut wouldn’t slide over it. We ended up using 2 of the eBay ones on each end and were able to put one on top of the other. This worked good.
Lastly, I bought a fuel pump originally thinking that was the issue, but didn’t need to use it. Amazon will be getting this back
Appreciate everyone’s help, pictures, and suggestions. You guys are the best!
Edit: the machine worked great prior to me running it out of fuel. After running it today, we were able to lower the RPMs with the same performance. The throttle response also seemed a lot better as well. My guess is that we had a slight blockage prior and when I ran it out of fuel it made it worse to make it not want to run at all.
