Jake615615
Ford New Holland 555E
Hello everyone,
First i just want to say I am new to the forum and excited to join you all!
Thanks to the forums out there I quickly leaned the operation of the brake system. I could not find the answers to the question below in any forum or even in the service manual or operators manual.
So i just bought this tractor, its my first real tractor. (have a Kubota BX23 with a backhoe if you want to call it a tractor). When i bought the tractor 2 weeks ago there was a warning light on the dash. I was concerned it was for oil pressure, but found the master cylinder empty. We filled it with Dot 3 and the light went off so i assumed all was well and not an oil pressure issue. (did not have a manual at the time and was standing there with cash). So after reading I quickly found i did a very bad thing with the Dot 3 and should be brake oil. I sucked the dot 3 out of the master the next day but the brakes had been already pumped multiple times (never did end up building any pressure). Messing with the brakes i found a popped brake line. I dont know if it was popped prior or if it popped while pumping the brakes this second go around. I have never been so happy to find a broken brake line and thought there might be a chance i don't have to get into the axle / brakes.
I installed two new brake lines and pulled the bleeder. The brakes now work excellent. Its been a few days and the fluid has stayed full in the brake reservoir. But i cant sleep knowing I'm sure some Dot 3 got in and is still in there.
Both manuals say to change the brake oil every two years BUT it does not tell you how? How the heck do i get the oil out of the brakes? I pulled the top big plug where the bleeder and lines go into on the axle thinking i could suck it out. That did not appear to be an option because it goes to two smaller holes with O-rings. I even had a skinny straw that fit but only went in maybe a 1/2 inch if that.
How screwed do you think i am?
How do you change the brake oil?
Thanks in advice for any advise.
Hello everyone,
