555a ford backhoe wiring diagram
jimg984
ronda north carolina
i have a repair manual for the 550 and 555 the wiring diagram in the book don't match up to the wiring on my 555A. would be great to have the proper diagram. working on getting the lights and caution lights working
thank you indvance
jimg984
Arabhacks
Banned
Texas
Underemplyed Operator
Wiring diagram!?
Hello.
What do you need to know?
There is very little to the wiring of the old fords.
From the primary terminal of the ignition switch is the feed to the switched circuits.
If the warning lights do not work and were intended to be controlled from the ignition switch, that is the first thing I would check.
Next I would check the fusible link, that is a section of wire with a plastic bulge and numbers on it, to replace it simply cut it out and connect a section of wire 3 gauge smaller than it as the jumper.
I hate test lights that are used to pierce the insulation, the damage will allow the wire to corrode from within.
jimg984
thank you Arabhacks for your reply and suggestions... the ford is new to me, all the ligths and caution lights are gone and most of the wiring going to them.. i understand Ing. feeding fuse and switches.. where i'm getting lost is what each switch does.. 1 twist switch says lights i'm sure that would be headligths and work lights.....2 is a lever type switch with three postions (?)..........3 is a pull out type switch with large knob (?) also has flasher mounted.......... so i'm thinging turn signals and caution lights.. there a large amount of wiring and is bundled together any more help would be great thanks again jimg984
Phil
Southeastern Ontario
retired operator and mechanic
If I remember I'll check my Ford 550/555 service and operators manuals. Using the switch with the right rating would be a good thing. Sounds like you are trying to keep it original. Phil:)
jimg984
Phil, thanks for your reply... yes i'm trying to keep everything orginal......... i forgot to mention in my last post that i have five fuses that are mounted in thru panel fuse holders, these are orginal also...the three switches are also orginal.
more input from anyone would be good
ths jimg984
HeavyLifter
Georgia
Hey Gents,
I have a 555c. Are the wiring diagrams the same. If they are, can someone send me a copy. It would be appreciated.
Thanks
mikedobosz
az
looking for a wiring diagram for a 555a. It just came out of burial ground and want to get it running. new starter but no idea of the placement of the 4 wires. Can someone please help?
jimg984
eric, I have sent it twice and get replys from postmaster saying site is busy if had your email address I could send it to direct you,,, the attempts are going thur this site
jg
