555a ford backhoe lubricants
Discussion in 'Tractor/Loader/Backhoes' started by jimg984, Mar 7, 2010.
  1. jimg984
    jimg984 Senior Member
    Dec 1, 2009
    606
    ronda north carolina
    i dont like paying ford dealer prices on lubricants for use in a well used 1985 backhoe......... example $80.00 plus for 5 gallons hydraulic oil
    need help converting the followinG Ford number from a Ford operators manual to something cheaper
    HYDRAULIC SYSTEM...............................FORD 48
    4X4 POWER REVERSING TRANSMISSION......FORD 41
    REAR AXLE............................................FORD 53
    THS IN ADVANCE FOR YOU HELP
    JIMG984 NORTH CAROLINA
  2. pinesd3400
    pinesd3400 Well-Known Member
    Feb 11, 2009
    136
    anything to bay the bills
    no. dighton, mass
    Hi I know youre concern, In my case my local Ford dealer where we bought it new
    closed up after 60 years. I have always used Ford New Holland Lubes filters etc.
    I now am forced to Napa using Napa's best (they also carry cheap stuff) Off my
    head may not be correct, but MC134 Hyd. oil used in Hydraulic, power steering
    and transmission. I have no problem at all with Napa, it also has printed on the
    container Ford JD IH Cat Case specs. and more. And the rear axle is plain old gear
    oil. I have never touched the rear axle since new and its still full and clean on the
    dip stick. trust me I wouldnt do anything to endager this machine. sam
  3. diggerdave1958
    diggerdave1958 Well-Known Member
    Jan 31, 2010
    246
    Michigan
    I have found that TRACTOR SUPPLY (TSC) has a lot of lubricants that will work in my Case backhoe i just matched the numbers on the buckets they have a chat with compatible fluids, hope this helps. the prices are getting out of hand at the dealers on fluids and filters. and i use baldwin filters on all my machines and save a few dollars per filter.
  4. jimg984
    Dec 1, 2009
    606
    ths for the replies........ i would like more input on the oil for the power reversing transmission....
  5. DGODGR
    DGODGR Senior Member
    Dec 18, 2009
    1,019
    S/W CO
    Do you have a bulk oil dealer that you can consult? The brand of oil is really not that important. It's the oil and the add mixes that go into it. Most all of the oil companies make oils that are made to meet or exceed MFRs specifications. The specifications should be available from your dealer or even on the container itself. Just take that spec and find an oil that meets or exceeds. I would try to find a good quality brand (I used Chevron for years), that is readily available in your area, and try to stay with it.
