I've been looking at that rubber return line going to the out arrow port for a while now,just like your question marks on the subject. The two out arrows are the same chamber after the filtered fuel. Possibly it's intent is to push return fuel out through the the other out arrow. I can't find any answers to that question. I switched the line to the in arrow. Now I have to reprime the system which is of course a nightmare. I'll try running it like that and see what happens before I investigate the fuel tank screen because last fall I completely drained and washed it out and cleaned the petcock filter so I'm leaning towards a different solution. I was a heavy construction electrical foreman for most of my 38 year career so I am quite experienced in logical troubleshooting. Never had a problem that wasn't solvable. I'll keep you guys in the loop. DanI HATE that filter set-up.. U see the rubber line connected to the the steel line,?? Thats the fuel return from the pump but the arrow is pointing OUT.??
1 other thing.. U ever heard of BRAKE KLEEN.?? Its a wonderful product for cleaning grease, grim & oil off of MANY DIFFERENT THINGS.. Lol
The problem your describing is a classic case of starving for fuel.. just like the filter is dry then refilling slowly.. like an oring is out of place.. or theres a vacuum problem..
BEFORE u try the outlet tap screen, try running it w/ the fuel cap OFF..
& dont try trouble shooting it w/ 5 gallons of fuel..
The main filter after the fuel tank inlet or the inlet on the Inj. pump?It’s the filter under the inlet nut .. it’s clogged..
If all else fails, & it sounds like it has, put an electric pump on it..
No more than 10 psi tho..
How many times are u gonna keep taking the same things apart w the same result.?? Just askin for a friend.. lol
Did that yesterday. No change.If pumpguy's suggestion isn't the problem, remove the the fuel tank filler cap after it the engine slows down or dies. You will be looking for /or if there is a vacuum in the tank. Plugged tank vents are notorious for the symptoms you have.
Just has a pet cock valve with a filter in the tank above it. all clean.Probably already covered this, but does it still have the needle valve and glass bowl under the tank? Those were terrible about clogging repeatedly. I take them out and replace it with a 1/4 turn ball valve.
Pump guy says. "It’s the filter under the inlet nut .. it’s clogged." But which filter?Just has a pet cock valve with a filter in the tank above it. all clean.
