if thats the case check your pilot pump pssure. at least it should be 700 psi with a very little pressure flactuation when you are giving pilot command.
the pump pressure i deceiving you mush monitor it when giving pilot command.
weak pilot pump would result to poor combined operation
I checked the pilot pressure and I got 500 PSI on the bucket pilot cap, also same for swing pilot cap, I read from the manual that it should be at least 740 PSI, this would be the regulated pressure from the regulating valve. At some point while curling the bucket the pressure would be zero and when it curled to an extent it shot up to 500, and sometimes fell to zero.
I got 250 PSI on the pressure reducing valve and I read it should be 512 PSI +/- 15 PSI. does this say i need a new pump?
I didnt test the pressure directly at the pilot pump outlet because i dont have the fittings for that connector. Do you think the pump is bad and what would be the damage?
