Tenwheeler
Three ways? 1: Intake plate or flap. 2: Vise grips in rack. 3: Cut fuel line?Make sure you have 3 ways to shut that engine down in case of a runaway.
YES! …..except I will just clamp off the fuel line and starve it.Three ways? 1: Intake plate or flap. 2: Vise grips in rack. 3: Cut fuel line?
an explosion......LOLUnless is pulling engine oil!!! AIN'T Nothing to stop it then!
If that appears to be going to happen run on a line parallel to the crank shaft not at a 90º to the crankshaft. And don't come back just because it gets quite as it may take a few seconds for whatever went up to return to ground and you don't want to be there to catch them parts!an explosion......LOL
How about dumping the fire extinguisher into the air filter intake?Unless is pulling engine oil!!! AIN'T Nothing to stop it then!
That might slow it down for a millisecond. Detroits move a lot of air normally. If it's running away on oil... All bets are off. A fire hose might stop it. Saw a 3-71 that went down bubbling in a lake, bent 2 rods and was running again the next day.How about dumping the fire extinguisher into the air filter intake?
Might be tempted to do that with a CO2 extinguisher but not sure I would want to dump a dry chem one down the intake. If you did I would think a major tear down would be the next step.How about dumping the fire extinguisher into the air filter intake?
Isn't that what pressure washers are for!? LOLMight be tempted to do that with a CO2 extinguisher but not sure I would want to dump a dry chem one down the intake. If you did I would think a major tear down would be the next step.
Yes, after engine is completely disassembled down to bare block!Isn't that what pressure washers are for!? LOL
I just meant into a paper type air filter. Heard of it but never done it. Just asking.Might be tempted to do that with a CO2 extinguisher but not sure I would want to dump a dry chem one down the intake. If you did I would think a major tear down would be the next step.
It will, if the E-stop is working or you have the blower bonnet off to use the board. A lot of the later engines had spring loaded rack levers and no E-stop flaps. Mostly the 92 series engines, but I have seen 71's with that setup too.If a Detroit runs wild from sucking engine oil why would shutting the air off via a board, estop, or other means not stop it. I understand that shutting the fuel off would have no effect. It can't possibly get enough air from the pan with the oil to keep running wild could it?
