4-53 detroit rattles on deceleration
Discussion in 'Other Construction/Demolition Equipment' started by crbearden, Jun 8, 2019.
  1. crbearden
    crbearden Member
    Jan 12, 2011
    6
    Piedmont, ok
    I have a 4-53 detroit powering an Ingersoll Vane type compressor. When the pump is up to pressure and the engine decelerates a loud clicking noise is apparrent. Sometimes this noise continues at idle, and then is intermittent. The noise is not heard when the engine is loaded however. I am trying to determine if this is in the lower end or a piston problem.
  2. td25c
    td25c Senior Member
    Feb 15, 2009
    5,148
    indiana
    Oil pressure on engine all cool between idle and full throttle ?
  3. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,816
    Mechanic
    Will county Illinois
    I would be curious if you have a splined coupler or a Lovejoy.
    mg2361 and DB2 like this.
  4. kshansen
    kshansen Senior Member
    Mar 11, 2012
    6,636
    Central New York, USA
    I was thinking along the same line, that the noise when compressor is unloaded might be looseness in the compressor or the coupling.
    Can you slightly open a valve to put a slight load on compressor but keep engine speed low to see if that makes noise go away?
    Or maybe take a video of it running and upload to YouTube then post a link here so we can hear it?
    mg2361 and funwithfuel like this.
  5. funwithfuel
    Mar 7, 2017
    1,816
    Mechanic
    Is this machine new to you? Are you new to driptroit? They have a tendency to have a "ring" from the accessory drives when at idle. Next question, how is your alternator driven? Belt or coupler? A video would be best as Kshansen suggested.
    DMiller, mg2361, DB2 and 1 other person like this.
  6. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,612
    Master Inj.Pump rebuilder
    Sunny South Carolina
    I'm w/ FWF.. check coupler between the pump & engine.. most likely place for a rattle..
    DMiller, RZucker and DB2 like this.
  7. OFF
    OFF Senior Member
    Sep 30, 2009
    745
    HD Mechanic/Shop Foreman
    Alberta, Canada
    I agree, got to be the coupler between the engine and compressor.
    DMiller likes this.
  8. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,414
    Oklahoma
