What should it cost to rebuild a 4.5 cummins it needs board they got it hot and cracked the head scoreing 2 cylinders? I have been checking around every thing it will need head, parts and machine work around $6000.00 then labor to put it together.
I saw one for 8000.00 but dont know if it would work just a add. I got a quote 9000.00.What can you get a reman for?
Its new from what i have been told there are a shortage of parts for the 4.5. I talked about haveing the head fixed with the machine shop and he said no in the past he sent other heads off for me or told me were i could take them. I am afraid that i will get to a point were i have several grand in this and cant find a part i need.The machine shops parts guy ask if i wanted to get the parts throught them great but after 3 days he couldnt come up with them. I called some other places but they didnt call back.Try> Reliance for parts.{ reman head & gasket kits}..
Did Cummins quote u NEW or Reman.. U have to specify, otherwise your getting NEW pricing..
Furnace weld heads on emissions engines? Valve seat height, width, valve protrusion, head minimum thickness, specified surface finish (varies from OEMs).Furnace welding is a standard procedure for fixing cracked heads. It's a tricky process though, so you may have to hunt for someone who can do it.
I dont know for sure but one resone i dont like reman is i have seen alot of them built out of junk. Alot of exchange engines are built out of cores that had problems not all but some are and until you have a problem you dont know.Just wondering what warrenty would get with an exchange engine ? Should the cost of a fuel system over haul be factored in to the maths ?
The other issue that I've seen and experienced it the quality of all the people in that process. Most rebuilding done now days was shipped out of the original manufacturer's states and put in right to work states or sent to Mexico.
1998-2000 customers' 855 Recon engines, quality-control issues like metal shavings from counter boring (chips about 1/4" long) found in bottom of oil pan @ 1st oil change. Cylinder blocks line-bored moving crankshaft centerline upwards causing timing gear breakage directly above the keyway. Cam follow boxes, used oil to pressurize-flush and clean; found copper-bronze chips from assembly. Cyl-heads: Shimmed valve springs, cross head guide height wrong (causes bent push rods). Crappy workmanship-quality control.I'm saying that the build expertise that came from the original manufacturing labor pool is not the same in the right to work states or Mexico. Quality control in a lot of those rebuilt components is not up to many of the original manufacturer's standards.
