3D Modeling
Discussion in 'Computer Applications and 3D Modeling' started by Tmerr, Apr 28, 2011.
  1. Tmerr
    Tmerr Member
    Jul 4, 2010
    10
    Lebanon,IN
    I use Trimble Business Center 2.2 to create svd and svl files for our machines and our layout controllers. After I am done elevating lines I use the 3D feature to look at the end result. The problem is that, to me, this only shows me obvious problems and not the subtle ones that I need to solve for the dozer guys. I have also used the machine simulation found in Trimble site vision office, but it takes alot of time to cover the entire jobsite. Does anyone have any suggestions as to what the best tool for reviewing a job once you have the ttm file and the linework. Obviously, I don't want to have to buy a whole new package. Maybe I am using the right tool and just need some tips on what to look for. Any help would be appreciated.
  2. morganasphalt
    morganasphalt New Member
    May 9, 2011
    2
    Salt lake city, Utah
    I just look at the surface in 3d view with vertical exaggeration up a lot to see if there is any foul ups or any places that i need to fix. What problems are you talking about the dozer guys may see that you don in the 3d view?
  3. Tmerr
    Tmerr Member
    Jul 4, 2010
    10
    Lebanon,IN
    Thanks for responding morganasphalt. I was playing with the vertical exaggeration and that did help some. I think my biggest problem can only be solved by experience. I need to get better at looking at
    what they are trying to accomplish instead of taking too literally what the architect has drawn.
  4. morganasphalt
    May 9, 2011
    2
    I also noticed a new tool in BC the other day. I don't have it open but if you right click on the surface and go to properties, then in the property pane under plan view or 3d view there's an option to turn on show slope arrows. That's helped me fine flat spots and other areas that are messed up. You can also use the surface slicer option.
    How do you like BC? Did you ever use Terramodel? I think its a huge step up from Terramodel.
  5. Surveyroads
    Surveyroads New Member
    Jun 6, 2011
    1
    alberta
    Hello! I Am trying to compare two surfaces the difference should be about 500 000 cubic m but its only 5000 any suggestions?????????????
    I measured from the same height and control point!
    I think its something I am doing in the drafting?
    Any help please
  6. Tmerr
    Tmerr Member
    Jul 4, 2010
    10
    Lebanon,IN
    Business Center
    Business center is light years ahead of Terramodel. Terramodel was like Greek to me. I wish that assigning elevations to lines was simpler. It is alot of work to constantly break lines and re-join them. I would like to be able to add an elevation to any point on the line by clicking on that spot. That would be nice.
  7. AGGIE SURVEYOR
    AGGIE SURVEYOR Member
    Feb 18, 2009
    15
    CONSTRUCTION SURVEYOR
    COLLEGE STATION, TX
    Run contours in smaller increments like 0.10'. You will quickly see the blips.
  8. MCguy
    MCguy Member
    Nov 9, 2011
    16
    Cleveland, Ohio
    When I am finished building any model I also run the contours @ 0.10' to really see how my slopes and grades look, especially when build a 8 mile highway with many variations of transitions ans slopes.
  9. Fredjones
    Fredjones New Member
    Mar 5, 2012
    1
    USA
    I like Modelling shows. I always watch online this show. I have not good knowledge about this but i watch regular...
  10. bethany22
    bethany22 New Member
    Dec 10, 2012
    3
    london
    Since I started 3d modelling, I have been using trimble, Most problems with trimble are their updates. Once it gets updated, the new user interface can be a bit of a challenge to use.
  11. KyleM
    KyleM Member
    Jul 11, 2013
    15
    GPS and Technology Manager
    Karratha
    Your dealer should be able to provide you with release notes that will show you what has been added or changed which should make it easier to adjust.
    Looking forward to the new look of TBC in 2.8!
  12. lodgey
    lodgey Member
    Jul 23, 2013
    7
    USA
    Indeed true. this is the best solution that one can provide. Contact with your provider buddy.
