Anyone know how to troubleshoot the 15SALH service code. Reason is because when you put the shift lever in forward the drive shaft makes a clunk noise then goes away. It dosent do it in reverse just forward. And it dosent do it while traveling just when in forward before any take off. The noise is like where the parking brake area is. I checked the wires to the forward clutch valve and looked good but not sure how to tell if the valve itself is causing the issue?
