rmllarue91
Hey hef got a good one machine is a basket case i diagnosed weak pumps last year upper pump was like 2k psi lower maybe 3k psi right track and bucket ( upper pump useless )they had another mechanic change o rings between main control valve half's recently. they had issues and had like 5 pilot lines crossed.... Sorted that out they ran machine Lil bit but said its time for pumps..... I put used Dyno tested pumps new oil and filters and main relief... The replacement pumps both build 5k psi when booming up and it counter rotates well when tracking seems like decent pumps. BUT the bucket and right track are totally destroying pump by way of less than 150 psi negative flow to upper pump as soon as pull a function . Lower pump left valve bank stays up about 500 psi under same single track function..... Any thoughts welcome
