345b excavator
Discussion in 'Excavators' started by tagaman, Feb 3, 2017.
Tags:
My 345b excavator cuts engine off when I try to operate implements at the same time traction is slow
Poll closed Feb 17, 2017.
  1. Excavator
    0 vote(s)
    0.0%
  2. Caterpillar
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    My 345b excavator cuts engine off when I try to operate implements at the same time traction is slow but engine runs perfectly
  2. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,615
    Equipment operator,mechanic
    S E Pa
    Any excess smoke coming out exhaust , try changing fuel filter ,draining water separator.
  3. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Bbbhhh
  4. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Nope there's no ex cess black smoke and service was done
    Recently
  5. DEMLONE70
    DEMLONE70 Senior Member
    Sep 30, 2012
    258
    Belgium
    Whats sn ?
    Any fault code ?
  6. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Unfortunately I can't tell because the cluster isn't working
  7. DEMLONE70
    Sep 30, 2012
    258
    Belgium
    First thing to solve then
  8. koecon
    koecon Well-Known Member
    Apr 13, 2013
    63
    Heavy equipment consultant
    Highland Ca.
    Have you tried the backup switches behind the arm rest to see if that makes a difference? Is the green LED on at the front of the machine controller next to the right front of the seat support?
  9. Marco olivetto
    Marco olivetto New Member
    Oct 18, 2014
    2
    Bazil
    Check diesel hoses. If there is no black smoke it can probably be fuel shortage.
  10. Marco olivetto
    Oct 18, 2014
    2
    Bazil
    Check the intake pressure sensor. The wrong dialing This sensor may cause problems.
  11. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Good morning
    On this machine of mine the engine runs perfectly if not underror load but drags soon after incorporating hydraulicso.
  12. Nige
    Nige Senior Member
    19,309
    I would say you are looking at a control issue in the hydraulic system that is not allowing the pump to de-stroke when hydraulic load is applied. That's what will drag the engine speed down.
  13. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Good morning Nigeria
    So what can I basically look at that makes the pump to destroke considering that the cluster is not working and I am financially not stable. Help me to just bypass something and make the machine to dig
    Regards
  14. Delmer
    Delmer Senior Member
    Jan 4, 2013
    7,249
    I'm no cat expert, but even a newer machine should have some visible smoke when it's being lugged down, right? If no smoke, then a turbo boost pressure test will give you some easy indication of engine power.
    I like the new hipster nickname, "White Nigeria", the senior cat expert.
  15. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Is there any way of bypassing the hydraulic loom
  16. Nige
    Nige Senior Member
    19,309
    If what I suspect is the problem is actually confirmed and you were to bypass something to prevent pump overloading lugging the engine down the machine would become so slow that although it would dig it would not produce anything because the hydraulics would have been slowed down to snail-speed. Unfortunately there are no short cuts here ......
    As Delmer pointed out, if the hydraulics not being correctly unloaded was causing the engine RPM to lug down the presence of black smoke should accompany it. Does this happen..?
    If you are "financially not stable" as you put it, then IMHO you really shouldn't be running a machine of the size of a 345. (other opinions may on this may be available)
  17. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Just to get this machine to dig
  18. Nige
    Nige Senior Member
    19,309
    Is it black smoking from the exhaust when the RPM lugs down - yes or no..?
  19. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
    Yes just a little bit
  20. tagaman
    tagaman Member
    Dec 1, 2016
    12
    southafrica
