92U 3406
How tight should the liners sit in the block with no lower liner seals? 92U PCTA Cat 3406.
And that, boys & girls, is why it took 5-6 tons to press the old ones out where the replacements simply drop in. You won't move them by hand once the filler band has expanded.Lube the liner seals with soap or something non-oily. Soak the filler band in engine oil, fit it to the liner and install the liner immediately. Clamp the liner down because the filler band will begin to expand.
92U 3406, you really need to clean that block up better I think I see a fingerprint between those two studs sticking out the front!Here's the project. Turning a W900A daycab into an RV hauler.View attachment 207428
Lol I think that's just the boss the fan hub adjustment bolt sits in.92U 3406, you really need to clean that block up better I think I see a fingerprint between those two studs sticking out the front!
Cmark pretty much quoted the Service Manual word for word ........... "Put liquid soap on the O-ring seals and on the cylinder bores. Put filler band (2) in SAE 30W oil. Then immediately install the filler band on the cylinder liner and immediately install the cylinder liner in the cylinder block with tooling (C) before expansion of the band."
