Hello ,I am working on a 85 L9000 /3406B that wont heat more than 130 ,new stat ,fan clutch still no heat. except in hard pull.Can someone tell me why the rad has two smaller hoses on the right tank one at top 3/4in.from head and one at bottom 1in. to water pump i think that is a bypass but that is the only part that gets warm, top rad hose andthe rest of the rad stay cold.should there be some restriction or check valves in the bypass ? Do thoes fittings, connect inside the radiator or does it just dump in, ?
Thanks
Thanks
