Cat_man320
My 330cl has a C9 Cat engine and runs fine , don't burn any oil and has plenty of power . My problem is that it doesn't want to start.
It spins and spins and doesn't fire . when it first happened , I was thinking compression as I got about 10,000 hrs on it now but I don't think that's the problem . I can start it the coldest day in the winter and sometimes the first flick of the key on a hot summers day but other times it will not start at all . I had the Cat service people come and do the computer checks with the lap top etc , The bitch started every time for them and they found no faults in anything....computers . fuel , injectors pumps etc etc . I replaced the check valve at the back of the head but no difference . QUESTION , Why will it start with a little spray of quick start ? It has new batterys , new starter and spins plenty fast , What is the line that goes from the front of the cyl head near the water pump and goes and screws into the ECM that's bolted on the side of the engine?. There is also what looks like some kind of pressure switch in this line too . So is it fuel running in this line or motor oil? I thinks it has something to do with this pressure switch and when the pressure builds up it trips the injectors to fire ? Just looking for opinions of what could be going on , especially where the cat dealer found no faults .
