Nitelite
Earlier, by mistake, I posted this on someone else's thread but I don't know how to delete it, so here goes again.
I have the D4E dozer and it has the Cat 3304 engine in it. I also have a Cat 951C loader with the same 3304 engine in it too. Having before gotten some really good pointers from some knowledgeable people on this forum, and the fact that a 3304 engine is still a 3304 engine no matter what machine it is mounted in, I decided to post my engine question here on the dozer forum as well as the loader forum to get the maximum input.
I could use some help in the way of input from some of the knowledgeable diesel experts and shade tree mechanics here.
My 3304 engine in my 86J--951C loader is blowing some oil or diesel fuel out of the exhaust stack. What would you think would be the cause? There is some whitish blue smoke coming out of the stack and some blow by out of the breather tube. The engine seems to run good. In the pictures you can see oil, or diesel, coming from a small leak at the exhaust manifold to muffler connection. Notice the oil running down the left half of the exhaust stack, in the pictures, it is the shiny side of the top of the stack because it is wet, and the flipper at the top is also wet. You can also see wet specks of oil on the painted hood after a few minutes of idling. I have not really worked the machine since I have owned it. I have installed a new inner and outer air filter and a fresh oil change w / filter. When I got the machine the inner air filter was stopped up and the outer filter was missing. The oil was two gallons low and very dirty. The oil filter was old and dirty but no metal dust inside.
I now have the gaskets and chamber o rings to stop the coolant leak at the chamber o rings. I need to drop the belly pan to hook up the sensor for the new converter temp gage and to get at the transmission filter for a fluid and filter change. Do I need to go ahead and do an in frame overhaul at the same time? New pistons, rings, cylinders and bearings? I don't want to do un necessary work but at the same time I would like to have the machine in good shape come spring.
The machine seems to run smooth and sounds good, but I have not cracked the injectors yet to test each cylinder. I will do that before I pull the pre chambers. The engine temperature gage did not work when I got the machine and I replaced the gage. It seems to run cool, just barely up into the green, but again, I have not really worked the machine yet.
Any and all comments are welcome. My D4E also has the 3304 and it has a dry stack.
