uffex
Good day Jon
If I am understanding your thread correctly the hose marked blue had its connection position changed to the tank, that is not correct to move the hose, when the machine is running the blue hose must have a minimum of 35 p.s.i and when you swing and let go of the RCV to stop the pressure must remain positive (Not zero). I suggest you check in the parts book check where that hose should connect make it good - adapt a low pressure gauge into that line and make sure you have the correct pressure. The pressure levels I give are the norm. for swing motors as I do not have Caterpillar information privilege's there are guys on the forum that can help with the exact numbers however in that absence use what I have given you. Excessive case drain pressure will only cause seal failure and be the root cause of swing motor failure.
I hope the information helps you to get it sorted
Kind regards
Uffex
Kind regards
Uffex
