319D was idling when the suddenly it sounded different.
Sounded different how? Misfire, Fuel knock, Sputter?
I pulled the fuel line from the spin on fuel filter to the engine and cranked the engine. About a teaspoon of fuel dribbled out for each revolution.
The fact that you built up pressure while cranking tells me you have plenty of fuel being delivered.
If you go into the service menu, diagnostics, EMU outputs, then look at aux extend/retract. Should read 0 until activated. I have yet to see auxiliaries stuck on machines with the roller switch.
"D" series hard start complaints are difficult at best. The reasons have been all over the map, from simple (type of oil, filters, fuel return check valves, cranking speed, etc), to more complicated (pumps/injectors, cam gear slip, bent pushrods). Unfortunately, in my opinion, you will be heading towards pumps. Have to eliminate all the simple stuff first.
Do you have the cold start option? How about a serial number?
