rmllarue91
Hey hef i got a 345bl blowing ecm fuse haven't got back to machine in few days but it's still on my mind. The wire is a white 14 gauge #123 it's got a splice dropping to 18 gauge for dlc connector. Anyways down an dirty i cut wire at ecm before it branches off. Rigged up fused power source and she still blows fuse. Next thought was unhook engine connector from ecm and try again.... The screw is stripped so i unhooked few sensors and injector connector. Still blows fuse. So here's my question anyone ever see this before?
Obviously I got more testing but it's on my mind and can't get to it at least to Tuesday. So I'm making a game plan first thing will probably be try beating an extractor in Allen head bolt and unhooking Conn 2 then trying fused power once again and then probably unhooking both ecm conn. and just powering up ecm with grounds and powers and see if ecm is just plain shorted. But if ecm is shorted what's a good plan for testing possiblecauses of shorting? I've seen injectors short out but usually just burn out driver. I've seen few smoked ecms from welding or bad ground but they never made a direct short. I've been using smaller fuse than called for trying to preserve short lol. Let me know how you'd finish diagnoses Thanks s/n 4ss308 i got schematic
