315BL
Discussion in 'Excavators' started by Crazysfarms, Nov 11, 2019.
  1. Crazysfarms
    Crazysfarms Member
    Nov 11, 2019
    6
    Mississippi
    Need help. 316 BL ignition switch has power to it but monitor will not come on and will not turn over ????
  2. Nige
    Nige Senior Member
    14,584
    Can you troubleshoot the electrical system with a wiring diagram.? If the answer is yes then need a Serial Number to identify the correct one for your machine.
  3. Crazysfarms
    Crazysfarms Member
    Nov 11, 2019
    6
    Mississippi
    3AW00954
  4. heymccall
    heymccall Senior Member
    Feb 20, 2007
    1,942
    Monroeville, Pa
  5. heymccall
    Feb 20, 2007
    1,942
    Monroeville, Pa
    The yellow from the key switch activates the main relay. Turn key on and check for voltage at yellow, here. Screenshot_20191111-195110_Chrome.jpg
    If voltage is present on yellow with key switch on, test the purple (main power) on the same relay's large post when yellow is energized.
  6. Crazysfarms
    Crazysfarms Member
    Nov 11, 2019
    6
    Mississippi
    yes purple has 24 volt.
  7. Crazysfarms
    Crazysfarms Member
    Nov 11, 2019
    6
    Mississippi
    Had volage on purple as well. Monitor is not coming on and will not turn over. Hoping not ecm.
  8. Crazysfarms
    Crazysfarms Member
    Nov 11, 2019
    6
    Mississippi
    3AW00954
