310G JD 2004 wont start (died while going in reverse)
Discussion in 'Tractor/Loader/Backhoes' started by DIOP, Jun 28, 2022.
  1. DIOP
    DIOP New Member
    Jun 28, 2022
    2
    houston
    The machine has been mine for about over a year.
    Battery is about 6 months old (only has one battery, I do not know if it needs 2).
    The machine has been needing a bit of starting fluid ever since I bought it in order to start.
    In order to shut off the machine there is a wire that goes to the ECU (I think that is the name of it) that you have to unplug. I believe the purpose of it is to kill the power to the fuel pump.
    I was using the machine on Saturday and it died on me as I was backing up (2 seconds or so after putting it in reverse). I Tried to crank it an it did not work. I tried again but with a bit of started fluid and it worked. I used it for about 3 hours and gave me no issues.
    Next day (Sunday) it started just fine ( I added 5 gallons of diesel) and after about an hour it died as I has been going in reverse for about 2 seconds (Just the way it did the prior day).
    What have I done since then:
    1-Changed the fuel filter (It was very dirty).
    2-brand new air filter
    3-performed oil change (Motor)
    4-Blew air into the fuel line that goes to the tank (unplugged the line from the manual pump/primer and blew air from that end onto the tank)
    5-Unplugged and cleaned (blew air with compressor) the metal line between the manual pump/primer and the fuel filter
    6-Unplugged and cleaned (blew air with compressor) the metal line between the Fuel filter and what I believe is called the High pressure Pump. The line was unplugged from the fuel filter and from the HP Pump.
    7. The fuel rail (which is metal) has a returned line attached to it at the end (which is rubber). I unplugged such rubber line and also blew air into it. I could hear all the air coming out in the fuel tank.
    8. Once I was done with steps 1-7. I tried to purge the fuel system (bleed the air out of it). I might have done this incorrectly.
    The machine wont start. It does start with starting fluid, but dies immediately after 1-3 seconds.
    Thanks for reading.
  2. jimg984
    jimg984 Senior Member
    Dec 1, 2009
    606
    ronda north carolina
    try taking the fitting out when the hose connects. be careful there could a ball and spring, don't drop or lose GOOD LUCK
  3. DIOP
    DIOP New Member
    Jun 28, 2022
    2
    houston
    Thank you for your reply. Which fitting would that be?
  4. jimg984
    Dec 1, 2009
    606
