hotsaw
I really appreciate this forum and want to thank all who so willingly take the time to write.
I am working on 310E Prentice that only swings one way. The pumps all check good pressure. I dead-headed the hose into the gauge coming from the valve to the swing motor and it has very little pressure. The other hose was good.
It has a CMX160 Vickers Load Sensing Valve section. I've been through just about the whole swing valve section and can't find much wrong. What am I missing?
Also when you try to swing the "bad" way the main boom will not lift at all. And when you swing the good way the brake will not come on in neutral. Anybody run into this?
Thanks so much.
-Hotsaw
Thanks so much.
-Hotsaw
