Canadian_digger
Went to start my 308 this morning and it would not turn over. Had it plugged in for a couple hours. It was -20c. It normally starts no problem.
When you turn the key on, the dash lights up like normal but when you turn the key to start nothing happens. I then got it going by jumping the starter with a screw driver. I ran it for 6hrs and when I was done for the day I shut it off and immediately tried to restart and same thing no start.
I then tried jumping the starter again, but this time it would only turn over the motor half a turn and the starter would disengage from the ring gear. Now I can’t get it started at all. Could it be the starter or is it a wiring issue?
Thanks.
Thanks.
