3 questions 580 c shuttle and tachometer
Discussion in 'Tractor/Loader/Backhoes' started by Doug Brown, Feb 19, 2021.
  1. Doug Brown
    Doug Brown Member
    Oct 8, 2020
    23
    Cedar City Utah
    Putting the new engine in my 580 c does anyone know how to get the old tach drive out of my old engine?
    Next question
    What kind of oil goes in the shuttle transmission and is there a filter for the shuttle transmission?
    Thanks
  2. Coy Lancaster
    Coy Lancaster Senior Member
    Dec 19, 2014
    1,414
    service tech
    Arkansas
    The tach drive is a pain but you can rig up a puller just match threads with a plug or cap with a piece of all thread and a pipe.
    The shuttle takes hy-tran ultra or equivalent and there is no filter per say for the shuttle just a suction screen.
    randy448 likes this.
  3. Doug Brown
    Doug Brown Member
    Oct 8, 2020
    23
    Cedar City Utah
    Thanks. I guess I'll build a puller tomorrow.
  4. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    6,015
    On A Riverbank in IL. USA
    Drill the center out of sae threaded bolt. A piece of flat stock with a jack bolt on each side and the drilled out bolt in the center.
    I use all thread for jack bolts with a nut on the underside of flat stock is what worked for me.
  5. Dirttracker18
    Dirttracker18 Member
    Nov 13, 2019
    16
    55605
    Are you certain about no filter?
    The 580 CK and the 580 B had a filter for the shuttle. It is located behind the grill on the left hand side. Lines go from the shuttle control valve up to the front where it is filtered and runs through a cooler. Did they change this on the the "c"?
  6. Tinkerer
    May 21, 2009
    6,015
    580C --- just a screen inside the oil pan.
  7. outlawspeeder
    outlawspeeder Well-Known Member
    Aug 23, 2020
    86
    USA
    I am in the beginning stages of rebuilding a shuttle drive. I'll let you know what is in my pan when I get there.
    Staying in line with this post, my tack stopped working. When I pulled the cable with it running I don't see any thing spinning.
  8. Tinkerer
    May 21, 2009
    6,015
    The drive usually has a fiber gear that is driven by the camshaft. They teeth on them wear completely off over time.
    I guess it is to protect the camshaft from being damaged.
  9. Larryv
    Larryv Member
    Feb 23, 2021
    18
    So. Illinois
    Sometimes the center hole wears out. Should be square to accept cable. If its worn, you are in for a nee drive. Takes a special tool and a slide hammer to remove. But since it's bad, find a fine threaded nut the size of the drive and force it on. You wont find a nut with that thread. It's super fine. Then get under the nut with couple of pry bars. It's a slip fit.
  10. Doug Brown
    Doug Brown Member
    Oct 8, 2020
    23
    Cedar City Utah
    I got the new motor In and running. The shuttle works great. I got the tach drive out also. I have a couple of rams that leaks like a $10.00 boat. I'll get them in the next couple weeks
  11. outlawspeeder
    Aug 23, 2020
    86
    USA
    Next question: where can you someone get a new tach gear?
  12. Doug Brown
    Doug Brown Member
    Oct 8, 2020
    23
    Cedar City Utah
    They are available through case with a big bill. I was quoted $300.00 that's why I tried harder to get my old one out
  13. Larryv
    Larryv Member
    Feb 23, 2021
    18
    So. Illinois
    Only from Case
  14. Doug Brown
    Doug Brown Member
    Oct 8, 2020
    23
    Cedar City Utah
    That's all I could find
  15. outlawspeeder
    Aug 23, 2020
    86
    USA
    Dam, Anyone have a blue print?
    Does it just pull/pry out? Is there a anything holding it in? Advice?
  16. Tinkerer
    May 21, 2009
    6,015
    drive.jpg $280.00 + tax from CNH.
    Agricultural equipment salvage yards sometimes have used ones. The last one I had a price quote on was $100.00
    It is pressed in, a friction fit.
    Blueprint for the drive ?
    Quite a long time ago I posted pictures of the puller I made. I'll try to find them if it would help anyone.
    I don't think the camshaft can be removed unless that drive is pulled out of the block.
  17. outlawspeeder
    Aug 23, 2020
    86
    USA
    I have my own machine shop.
    Tinkerer likes this.
  18. Tinkerer
    May 21, 2009
    6,015
    This is the puller I made for a Case 301/336 block.
    An 3/4" SAE bolt was used. I don't know where the other jack bolt is.
