KevD815
Ok, so its time to replace my welding truck. My current chevy 2500 just cant handle the weight of my welder, tools, and ladders. Toss in torch tanks and materials and the truck is clearly overweight. Fuel milage is terrible and its a pig on the highway. I've been looking at some slighlty older F350's F450's, and Chevy 3500's with flatbeds and service bodies. The 2wd models of these trucks are significantly cheaper. I could afford a truck thats about 5 years newer if i go 2wd over 4wd. I should probably note that i have been looking at the longer wheel base trucks too.
That being said, i need to do some plowing this coming winter. Nothing too crazy, a dozen or so driveways and a medium size parking lot. Its all pretty flat but a few places get a little hilly and there are some long pushes.
So what do you veteran plow guys think? Can i get the job done with some good tires and a bunch of weight? My welder, tools, and torch weigh in at a little over 1,000 lbs. Also, would a bigger/heavier plow help keep the front tires planted or would the extra width just make it harder to push? Most of my plowing experience hase been with 1/2 to 3/4 ton trucks with smaller blades so im not quite sure what to expect with a heavyweight dually.
Thanks guys!
Thanks guys!
