New 299D3 owner, new to DEF.
Received 3516-18 code, “Catalyst Reagent Concentration Low-Moderate Severity”
just received my machine (used, 2020). I know it’s been mosty sitting for at least 6 months, so plausible that the DEF has deteriorated in the tank.
DEF level shows >50% on the gauge so I figured first step is to drain existing DEF and replace with new. I bought a hand siphons pump from Harbor Freight which has ~36” inlet hose. Was able to get that about halfway into the DEF tank before hitting solid resistance (feels like hose is hitting the bottom of the tank). I backed it off a little and started pumping to start the siphon but no luck, just getting air. Retried several times, same result.
is there a better way to drain the DEF tank, or perhaps a better way to address this issue?
Thanks in advance…
Thanks in advance…
