Got it. But is there a switch that controls the aux hydraulics I need? People have mentioned it but I don't ever remember hitting a switch?
Not that I can see. This is the best explanation I could find for engaging the AUX hydraulics.
When thumb wheel (29) is moved, pilot oil is directed to the auxiliary circuit spool located in the control valve. Thumb wheel (29) is a proportional switch. Move the thumb wheel slightly for a small amount of flow to the auxiliary couplings. Move the thumb wheel further in order to obtain a higher flow to the auxiliary couplings. When a high flow work tool is detected by the ECM at the work tool electrical connector, and the thumbwheel is at 100% the switch will trigger the high flow mode giving maximum flow. Refer to "High Flow Mode" in this manual.
Move the thumb wheel forward in order to increase the flow of oil to the male "Aux 2" coupling. When you move the thumb wheel (29) forward, the ECM activates a solenoid allowing pilot oil from gear pump (charge oil) to activate the AUX spool. Supply oil from the piston pump (work tool) flows through the spool to the male "Aux 2" coupling. Oil from the piston pump flows through the work tool circuit and retiurns through the female "Aux 1" coupling to the spool for the auxiliary circuit. The oil then flows from the control valve (work tool) back to the hydraulic oil tank.
Move the thumb wheel backward in order to increase the flow of oil to the female "Aux 1" coupling. When you move the thumb wheel (29) backward, the ECM activates a solenoid allowing pilot oil from gear pump (charge oil) to activate the AUX spool. Supply oil from the piston pump (work tool) flows through the spool to the female "Aux 1" coupling. Oil from the piston pump flows through the work tool circuit. and returns through the male "Aux 2" coupling to the spool for the auxiliary circuit. The oil then flows from the control valve (work tool) back to the hydraulic oil tank.
