Currently in the process of changing the right side hydraulic drive motor hoses. I want to make sure I hook them up correctly. Have found a diagram that shows the connections on the pump end (top front is forward, bottom front is reverse). Can't find a diagram for the drive motor end. Can anyone confirm if the top connection is reverse and the bottom connection is forward? Thanks!
