287c cat
Discussion in 'Skid Steers' started by Pilot, Jun 4, 2019.
  1. Pilot
    Pilot Member
    Jun 3, 2019
    5
    Rusk Texas
    2008 287c skid steer Replaced demand pump (seal was leaking) ran machine about an hour worked great next time I use it ran about half hour then lost rpm and power. At full throttle rpm is only 1200 rpm machine won’t move. All other hydroelectric work great. When raising Or lowering boom the rpm goes to 2500 rpm machine moves fine stop using hydraulic rpm drops run rough smokes and feels like motor is loaded up. Change all filters new hydraulic fluid changed pickup pump , put old fan back on no change . Need Help
  2. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    817
    heavy equipment technician
    victoria,Australia
    Serial number please.
    Does this machine have the optional high flow? Also have you rechecked over every thing you have done?
    Mark
  3. Pilot
    Pilot Member
    Jun 3, 2019
    5
    Rusk Texas
    Ser#CAT0287camaso1542. Yes it has high flow. Put new fan back on . Just took all valves on valve stack off one at a time checked O-Ring and ohm coil not sure what all resistance should be but they were about the same .that said I can turn off the auxiliary Hydraulic same problem
  4. Mark250
    Aug 30, 2015
    817
    victoria,Australia
    Hi sounds like your pump is stroked up for some reason
    First off start the machine and operate the RH joy stick in all positions including the thumb wheel and buttons if equipped and note the engine condition, if one position does not make a difference let us know
    if no difference from above, disconnect and block the hose going to the pump control valve and try the machine to see if the engine still loads up
    this should tell us if you have a problem with the pump stroking up or not
  5. Pilot
    Pilot Member
    Jun 3, 2019
    5
    Rusk Texas
    Disconnect and and block the hoses going to the pump control valve no change
  6. Mark250
    Aug 30, 2015
    817
    victoria,Australia
    It sounds like your pump is stroking up, either by a faulty control on the pump or mechanical issues i.e. swash plate locked up
    Have you the ability and tooling to check pump pressures?
  7. Pilot
    Pilot Member
    Jun 3, 2019
    5
    Rusk Texas
  8. Pilot
    Pilot Member
    Jun 3, 2019
    5
    Rusk Texas
