262C Fuel pump water leak
CTS229
G’day I was wondering if anyone could shed some light on this issue I have. I’ve got a 2011 262C with a C3.4 engine and machine prefix MST that has some form of water governor on the side of the fuel pump which is leaking badly but not affecting the fuel side of the engine. Can I bypass this? I’ve looked on web sis and on tmi but cat won’t sell any repair/reseal kits for this part. And I don’t wont to replace the fuel pump if I don’t have too.
Cheers
kshansen
Central New York, USA
Water governor on a fuel pump, that's a new one on me! Hope someone can chime in with some information.
Any chance of a picture of the item showing where the leak is?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Its just a COLD START devise.. & YES u can bypass it..
I don't think it is rebuildable.. its just an oring that's leaking tho.. Take it to your local fuel shop & see what they say.. or call them.. tellm u have a coolant activated CSD.. like on the Volkswagon diesel inj. pumps & see if they will rebuild/sell u one.
They may have an old one on a CORE pump..
Give'm the 104742-3100 # {Zexel} & they'll look it up to see if theres a breakdown of the CSD or if it shows it as an assembly..
kshansen
Well I guess I can go back to bed now as I learned something new today!:cool:
thepumpguysc
The pump timing is retarded until the water temp comes up.. in that gizmo that's leaking, is a "wax motor" that heats up & allows the normal timing to resume..
kshansen
"Wax Motor" so it works similar to the way a temperature regulator does to control the flow of water either back to the engine or out to the radiator?
thepumpguysc
Not really.. theres a constant flow across the wax motor.. & when it gets up to a predetermined temp, the wax melts & allows the lever to relax, putting it in a state of "non-operation"..
Then when it cools, the lever is "active", pulling the inside roller assembly to the retarded position again..
