Craig Skaggs
Firs time poster, after researching my can off everywhere, there seems to be a ton of experience on this site.
Long story short, there has been an addition of a new piece of equipment that I do not know the history of. It is a 259d Caterpillar skid steer(~2500 hours) with travel problems. My brother actually purchased this skid steer knowing it had issues and I ended up with it in my shop. It will travel in forward and reverse very slowly but if you pick up speed it will throw an error code of E569-2 "Unexpected left motor reverse speed detected". When it first arrived at my shop this was the condition it was in and upon further inspection I found the right final drive was extremely low on oil and was growling and vibrating when trying to move the machine. I did find metal in the oil and made the decision to change the final drive with a new unit from finaldrivemotors.com. The other final drive was full of oil and no metal particles were found.
After changing the final drive I ran the machine for a small amount of time to get the hydraulic oil circulating to change the filter, one because it needed it and another symptom it had was the hydraulic oil was getting hot and alarming. Hoping the final drive was causing both issues, after pulling the filter and inspecting it by cutting it apart and squeezing the oil out I found no metal particles! After the hydraulic oil change I scanned the radiator with a flir thermal imaging camera and found the radiator was doing an excellent job of exchanging heat and found nothing getting too hot. It doesn't seem to get hot just sitting and running you have to be driving to get the hydraulic fluid to an alarming temperature.
My mind is going to the final drive "brakes" are not unlocking, I read where there is a charge circuit that will need pressure before they will release but I do not know how/where to check that. Also when it throws the error code it mentions the speed sensor and associated wiring. I did do a continuity test of both speed sensors and found a discrepancy between the two, although it is minor it would be nice to know what the resistance should be between the pins.
I switched the wiring from left to right on the speed sensors as well and it actually threw a different code after that but did go to the right side. The code was: Right drive motor speed sensor #2 abnormal frequency, pulse width or period,
Any help would be appreciated!
