This might be common sense, but, dont forget to check out the hydraulic oil filter and just pour out the oil to see how much metal and brass shavings it has. Also depending on how many hours it has, it will eventually need to have the DPF Filter service, weather its replaced or cleaned and it can be a bit expensive. Hope it works out.I’m going to check out a cat 259d tomorrow and was wondering if there’s anything I should be looking for?... any common issues with this machine?
It’s tier4. what are your guys options on tier4 stuff so far?
